Jakobud
On my home network I have a wifi router, and then ethernet that runs to several rooms in the house. I want to add an Access Point to one of the rooms in part of the house where there is poor wifi reception. There is ethernet run to this room.
I'm looking at the following Trendnet Wireless Access Point:
http://www.trendnet.com/langen/products/proddetail.asp?prod=140_TEW-638APB#tabs-solution02
Will this work for me? I don't want the access point to be a range extender type of thing. I want it to be hard wired with ethernet directly to the router in the house.
I want there to be a single SSID for the house. So do I just set up the AP and the router both with the same SSID and just use different channels and I'll be good to go (as long as the AP is obtaining an IP from the router properly)?
