Windows 7 Samba
Softail
In order to connect to the samba share from Windows 7 I needed an smb.postconf script
pc_replace "max protocol = NT1" "max protocol = SMB2" $CONFIG
SMB3 doesn't seem to work but is only relevant to 8.1 AFAIK.
Is this safe? Is there any reason such a low level is wired into the smb.conf file?
SMB3 is not supported by Samba 3.6.
SMB2.02 is only supported in my recent releases, however it carries a performance penalty, which is why I left it disabled by default. On my Win 8.1 test setup the performance drop with SMB2 was over 10%.
To enable it, you can use the following commands over SSH:
nvram set smbd_enable_smb2
nvram commit
service restart_nasapps
Any older or Asus firmware only supports NT1, as the Samba version used does not support anything newer.
