Hi All,
First time poster. Been running Merlin on my Asus router. Very satisfied and basically no issue for the past year, and if any it won't need that much of digging in.
I'm a Verizon Fios user and I used to connect my Asus router to the Fios modem which is connected straight to the internet. That created a double NAT issue for my Asus router. I very recently discovered that when trying to set up DDNS. I have since corrected that.
However, I have also discovered that:
- Both of my Windows devices that connect to WiFi wirelessly would automatically disconnect themselves every day or two. Next to the AP entries would say "need action" on the list of avail. hotspots. If I manually connect to any of them, there would be an authentication redirect popup just like those public WiFi hotspots. However Diversion is blocking the MS auth domain...so I have to shut down Diversion to complete the authentication process. Notice that if I leave the auth page alone I can still access the internet without any issues, but Windows will keep telling me the WiFi has "no Internet". I still have to repeat the auth process regardless of passing the auth or not every day or two. I have never run into anything similar before the change. What could be the cause of it? Is there a config entry that I can toggle on Merlin?
- With the Fios modem I kept a fixed IP address for the past year or so, but after Asus ruter takes over I am assigned a different IP address every two days ish. Does DDNS have to do with that? Or does it have to do with the above symptoms my Windows devices are having? Any ways for my Asus router to be less aggressively requesting for a different IP? Will cloning the MAC address of the Fios modem help?
FYI I'm running the latest version of Merlin.
Many thanks in advance.
