Wired device not listed in main router, only APs
a-seus-am-i
I have a 3 router setup with an 86u as the main router and 2x 68u's as access points. I have a hard wired device that will only show up in the network map on the APs and not the main router for some reason. The device is not wired directly to any of the routers. Everything comes into a switch first which then connects to the APs and devices. Any thoughts on why this might be?
In general, I've noticed the network map being inconsistent. I have 1 device that still shows up in the network map, but has been turned off and disconnected a while ago. I have a few devices that show that little "2" for the "2 clients are connecting to this 68u through this device" although I suspect this is because the device bounced from APs maybe. And there are devices that don't show up in one, but show up on the other, etc.
Running 384.14.
As has been mentioned many times before in these forums the Network Map is inconsistent. There is nothing Merlin can do about it because the code is closed source (and Asus often changes it).
