better than I was expecting
I was expecting closer to 500-550 Mbps considering the lack of NAT acceleration on top of the CPU usage from the cipher.Isn't it as expected? This router has quad 2.6GHz B53 CPU. B for Broadcom version of this ARMv8 core. I've got around 470Mbps on my quad 1.5GHz A53 CPU gateway (A in Qualcomm version). I believe with further optimizations this faster CPU router can go higher.
I don't see NAT acceleration going away as Internet connection speed is outgrowing the pace of home router SoC development. We have some countries that are now offering 10 Gbps home connections. Even Bell started to hint at 8 Gbps (until they started sulking because the CRTC wouldn't let them screw everyone over). However NAT acceleration and flow caching can be made more intelligent and capable of dealing with various protocols. I suspect that Broadcom' flow cache is probably just lagging behind Qualcomm and Mediatek in that area.I expect this to change at some point on a hardware level. MediaTek Filogic 830 with quad ARMv8 2.0Ghz claims up to 900Mbps on WireGuard. I see online some folks got >700Mbps on this platform. Qualcomm IPQ5322 with quad ARMv8 1.5GHz does FQ-CoDel QoS at >800Mbps perhaps with the help of some hardware flow control. Software NAT acceleration is perhaps going away.
Do you know what speed is expected if someone wants to bypass the Bell gateway and use their Asus BCM4916 router instead? This is good to know.
Seems like it works pretty well. I remember PPPoE was single threaded and NAT acceleration incompatible.
Our whole Internet situation in Canada is... single threaded with high cash flow prioritization.
I don't know, but my router barely shows any CPU usage when pushing it to 1 Gbps - Flowcache works with PPPoE. It's probably NAT acceleration that helps the Gigahub handle that speed.Interesting how Bell made this work with PPPoE. Perhaps their Hub has some multi-threaded processing trick. Do you know what speed is expected if someone wants to bypass the Bell gateway and use their Asus BCM4916 router instead? This is good to know.
Welcome To SNBForums
