xkill
Yesterday I upgraded the firmware to RT-AC68U_380.57_0, but I had a problem. The wireless on 2,4Ghz stopped working.
Situation:
I have QoS set manually with my own rules, but it worked fine since two years on different versions of the firmware, so I think that it is not the problem
I reset the configuration to default and start to configure manually again, everything worked fine until, my last step, I enabled the Guest Networks, and both SSID stopped working (only 2.4GHz, the 5GHz networks was still working fine)
I rolled back to RT-AC68U_378.56_2 and started working again.
I don't know what is the best way to report a bug, but that's what I can do.
MORE confs: PPPOE, DHCP, no VPN, no IPv6, no special firewall rules only the default check to enable the firewall, no parental controls and no MAC filtering on the wireless configurations (guest and no-guest).
Situation:
- 2.4 GHz
- SSID: OoloO
- WPA2 enabled
- 2.4 GHz Guest
- SSID: OoloO Free
- Open
- 5GHz
- SSID: 0olo0
- WPA2 enabled
- 5GHz Guest
- SSID: 0olo0 Free
- Open
