Wireless Config reset to default?
JohnOCFII
Greetings,
Over the last week or so, I've noticed the 5 GHz wireless signal "disappear" for a while (maybe 15 minutes) then come back. 2.4 GHz has been fine. This on my main router, an RT-AC68P running 380.69_2.
Today, in preparation for upgrading my RT-AC68P to 384.3 I noticed that both wireless network had somehow been reset to their default configuration!
I hadn't noticed since I also have an older RT-N66U running 380.68.4 in AP mode with the same two SSIDs.
Has anyone seen this behavior before? Any reason this should change my plan to upgrade the RT-AC68P to 384.3?
(And, yes, I should also upgrade the RT-N66U to 380.69.2).
Thanks for any advice.
John
