Wireless Log not showing details on connected guest clients
unknown14725
Tried searching for answers to this, but didn't find anything relevant. Maybe someone here knows.
Asus RT-AC66U (Asuswrt-Merlin 3.0.0.4_376.48_1)
Wireless Log doesn't show name, rssi, rx/tx rate on clients that are connected via my guest network. I sometimes have up to 10 clients on my guest network, and it would be nice to see more details on each of them in the Wireless Log. Is there some sort of setting that does this? I cannot figure it out, and it's very frustrating. I've had this problem all the time, and it's not isolated to the recent firmware version.
Clients that aren't on my guest network will show all info. I.e. "DCS-6010L" below. And usually if I have many guest clients, they will all display the same Name. (In the example below they just happen to be blank at this moment. Don't know why. Fairly random.)
Example:
Mode    : AP Only
Stations  (flags: P=Powersave Mode, S=Short GI, T=STBC, A=Associated, U=Authenticated)
MAC               IP Address      Name              RSSI    Rx/Tx Rate   Connected Flags
28:10:7B:06:F7:C4 192.168.0.8     DCS-6010L        -54dBm   ??/19 Mbps   00:14:05   AU
50:46:5D:7F:CD:5B 192.168.0.204                           AU
40:0E:85:43:66:74 192.168.0.219                           AU
Seems like no-one has a solution.
I'm trying to troubleshoot, but it's kinda hard when I dont know if this is a flaw/bug in the firmware, or if it might just be borked settings.
Does anyone else have the same issue on their own router? Or does it work fine for you?
Have you ever done a reset to factory defaults and manually entering only the settings needed to get the router going?
I have the RT-N66U and it shows properly here.
Thanks for checking it for me.
I just did a factory reset, and Immediately after only enabling the guest network I still have the same issue. So I am confident it is not a custom setting that is causing this problem.
Does anyone else experience this with the AC66U as well? Or am I alone with this problem?
