Wireless log
jpdsc
Hi all,
Is it possible to know when a wifi devices was logged on the network and logged off?
I have jffs enabled so I could use a script if anyone has one already.
Thanks in advance.
Cheers,
There has been a few different threads asking about this, particularly with regard to home automation systems. If you search for those threads they might have what you are looking for.
Thanks Colin, I checked but no real solution. Shame the syslog does not log when a wireless client connects and disconnected :-(
AFAIK the only way would be to periodically poll the list of associated clients. By comparing "before" and "after" lists you could determine which clients have been added or removed.
http://www.snbforums.com/threads/wl-assoclist-command-with-two-ssids.21497/
Depending on the router (you don't mention which one you have) this might be simple enough. It starts getting a bit cumbersome if you have guest networks as well as the normal 2.4 & 5 GHz bands.
Hi @jpdsc , I've put together a quick and dirty script which might help you. I haven't tested it very much but it seems to work.;)
It's not fool proof and doesn't distinguish between different bands, but it's something to start with.
/jffs/scripts/wireless_monitor.sh
#!/bin/sh
oldlist=/tmp/assoclist.old
newlist=/tmp/assoclist.new
touch $oldlist          # Create an empty file the first time through
while sleep 15
do
        for iface in $(nvram get wl_ifnames)
        do
                wl -i $iface assoclist | awk '{print $2}' >> $newlist
        done
        for macaddr in $(grep -vxFf $oldlist $newlist)
        do
                arpinfo="$(arp -a | grep -iF $macaddr | awk '{print $1 " " $2}')"
                logger -t wireless $macaddr $arpinfo "has connected."
        done
        for macaddr in $(grep -vxFf $newlist $oldlist)
        do
                logger -t wireless $macaddr $arpinfo "has disconnected."
        done
        mv $newlist $oldlist
done
/jffs/scripts/services-start
#!/bin/sh
/jffs/scripts/wireless_monitor.sh &
