soleillune
Here is my experience with wireless printing :
I own two Epson wireless printer, same behavior for both.
If I print small document, no problem.
If I print photo (meaning large file), the problem begin:
-With ASUS RT-AC68U, 4561 Asus firmware, it start printing normally then it slowdown then I get a communication error from the printer and the retour reboot by itself.
-With ASUS RT-AC68U, Asuswrt-merlin 374.40 alpha4 firmware, it start printing normaly then it slowdown and continue to print very slowly until the end.
-With ASUS RT-AC68U, 4881 Asus firmware, it start printing normally then it slowdown and continue to print very, very, very slowly until the end (it took half an hour to print a 4x6 photo).
-With ASUS RT-AC68U, 4881 Asus firmware and Universal beamforming disabled, It start printing normally then it slowdown and continue to print very slowly until the end.
-With ASUS RT-AC68U, 5047 Asus firmware, beamforming enabled, It start printing normally then it slowdown and continue to print slowly until the end (it is the least slowly for wireless printing).
-If I print using my old Linksys WRT 160N V3 router, everything is OK and Wireless printing is the same speed as hardwire printing.
-If I print using my linksys EA6500 router, speed is the same as ASUS RT-AC68U, Asuswrt-merlin 374.40 alpha4 firmware.
Next, I will try the Asuswrt-Merlin 41_alpha4
Any idea of what is causing the slow printing speed?
I hope this will help developpers
