JoyceBabu
I am planning to buy a new Wireless Router. The router will be used in a SOHO environment. There are 6 computers that work simultaneously, and it might increase up to 10. The firewall (stock firmware / custom firmware) should allow me to selectively block/open outgoing ports. It should also allow me to re-route all outgoing traffic on ports 80 and 443 through another firewall / content filtering server.
I have been reading about several reviews and found several positive reviews on ASUS RT-N16. Will it support my requirements above? Also, it would really helpful if you suggest what ADSL modem I should by along with my router. I already have a NetGear 834Gv5 router. Can I use it as a modem?
Thanks in advance.
Thanks in advance.
