Wireless upload speed inconsistent on PS4, google fu used up...
frustratedpdx
I truly appreciate anyone's time, I know this post is long but I want to try and answer any questions upfront. I know there is a solution here, just struggling to find it. Thank you in advance.
I am going to try and breakdown this down as painlessly, and with enough detail to help anyone who wishes to offer suggestions. With that in mind, I am not a networking person. In fact, in the 10 plus hours over the last two weeks I’ve spent on this, is my sole knowledge base.
The ISP
I live in Portland, Oregon and have Century Link gigabit fiber. Initially I had fiber, but was only at 100 up/100 down. I decided to upgrade, and a tech came out as I also needed a new jack installed. Once the install was complete, I observed via his windows 10 laptop on safe mode pull 920 down and 898 up. During my trouble shooting process I feel confident in ruling out the isp. The other devices in my home pull anywhere from 560 to 700 up and 500 down wirelessly.
The PS4 problem
I am experiencing wild swings in upload speeds. I will attempt to post pictures of these tests in order. I use the PS4 for all streaming, as well as gaming. The gaming portion is making me possibly cling to the upload speed more than I need to. However I feel an upload speed that is consistently 10% or above of download speed is reasonable. I have spoken to Playstation and been told to open ports.
I assigned a static IP through the router, and opened up all of the requested ports. Sometimes I can 20mbp down, but another test shortly after will drop to 4mbp or even 700kbp. I tried multiple snake oil tricks online and nothing has worked.
The only time I found the consistency was by accident and strange, however it resulted in a NAT type failure on the PS4 test. For a handful of test in a row, it said my NAT type failed yet, I was getting 160down and up to 90up, and it was consistent. However I didn’t want to leave the error. So I’m thinking that it might be something within NAT settings that I have missed. So here is where I’m currently at, and what I have done with the router.
Unfortunately I had been on the phone with ASUS, who were completely un helpful. This NAT error occurred after a power reboot of the modem, and before I re entered the ports to be forwarded. I don’t know what caused the error which ironically allowed the consistency. But again, I feel the answer is somewhere in how the NAT and PS4/modem are communicating.
When I’m in the same room, with macbook pro I have no problems with consistency or upload. I understand they are different devices, but it just is getting frustrating at this point. Lastly, no other device, except when I test via the macbook are connected on the 5g network that the PS4 is.
Router
ASUS RT-AC88U running 382.1_2
Under LAN settings I have 201 set for my VID (prior to that I was only getting half the bandwidth)
Under WAN settings all of my basic config’s are set to YES, and I have touched them. The only thing I did was change the internal UPNP allowed range from 1 to 65535
Port Forwarding has the ports given to me by Playstation to open, 80, 443, 3478-3480 tcp and udp ports 3478-3479
NAT Passthrough
Everything is set to enabled, with only enable PPPoE Relay disabled.
Thank you again for anyone who replies, I know it is a long post. But I want to get to the bottom of this. I have read countless posts, and even looked through this forum regarding other issues that might be similar relating to speed but haven’t found a solution. Thank you!
Have you considered that the fluctuations in speed are caused by Sony's servers and are nothing to do with your equipment or the ISP? If you can get consistent speeds from a PC connected to the router then that's probably the problem.
Also, remove all those port forwarding rules, they are not necessary. Sony says those ports need to be "open". On the Asus all outgoing ports are open by default. Make sure you have UPnP enabled on the Asus (WAN > Internet Connection) and that will take care of any incoming ports. [Remember to reboot the PS4 after making these changes.]
The amount of data that speed test transfers is no where near enough to get a good representation of how fast its connection is.
It has always low balled my connection around 50-70Mbps. When I run SpeedTest.net right after from my computer it pegs my 150/150 connection.
Also my rule of thumb is: If you don't move it. Use Ethernet.
Just for giggles, try an ethernet connection - if the problem still exists, then it's the Ps4...
