Hi all.
I have a cable TV box that uses a RJ-45 eithernet port to get updates from the Internet.
I also have a good-working Wifi network.
So, is there some adapter that can read the wifi signal and sent it to the TV box? The Box only has RJ-45 - cannot use a USB wifi adapter. The box is also well within range, so I don't think I need some repeater. There is only one connection, so I don't need a hub (maybe some small router/hub is more flexible)
I looked at power-line adapters, but those are bulky, slow, and use more than ~20w just being on.
Any ideas?
ok thanks!
Erric
Any ideas?
ok thanks!
Erric
