WL assoclist Command with two SSIDs
habnix
Question: I have two SSIDs "SSID_2.4G" and "SSID_5G".
The command "wl assoclist" gives me a list of connected clients' MAC addresses which I can then query using wl sta_info MAC_ADDRESS
However the WL command only shows me clients connected via the "SSID_2.4G" not clients connected via the "SSID_5G".
I tried "wl -a wl0 assoclist" and "wl -a wl1 assoclist" but all I get is "wl: wl driver adapter not found"
How can I fix this and get a list of *all* wireless clients connected to *any* SSID. Thanks for your help!
You might try including the interface, like "wl -i eth1 assoclist". On my RT-N66U "eth1" is the 2.4Ghz spectrum and "eth2" is the 5Ghz.
@Nullity is correct.....for Broadcom hardware
wl -i eth1 assoclist (for 2.4Ghz)
wl -i eth2 assoclist (for 5GHz)
And if you have an 87U it's different for the 5GHz band because of the different hardware....
qcsapi_sockrpc get_count_assoc wifi0
This will tell you how many clients are associated. After that, you have to query the router for every client. So if you have a count of 2 clients:
qcsapi_sockrpc get_station_mac_addr wifi0 0
qcsapi_sockrpc get_station_mac_addr wifi0 1
This will return the MAC of associated clients 0 and 1 (the index starts at 0).
