Tim or others that own this box, how hot does it run (wasn't mentioned in Tim's review)? Other boxes with GigE apparently run hot as pointed out in reviews here and elsewhere. A lot of failures are reported on the E3000 and the DIR-655 is also reported as running very hot.
Is Netgear design any better for handling heat? Also, any opinion on vertical or wall mounting in terms of heat dissipation?
