Bloodstriker
I'm having trouble with my WNDR3700. I've been using this router since the beginning of the year without issue.
All of a sudden, I'm starting to experience exteremely slow wifi speeds.
I've tested via the wired connection and the speeds are where they should be.
The problem has to lie somewhere in the home wifi network and not the ISP. I tried transferring a large file from a wired desktop to a wireless laptop and the file was transferring at approx. 800kbps. The laptop is withing 5 feet of the router and was at 99% signal with a 300Mbps connection and I've tried this both at 2.4 and 5GHz.
The slowness if effecting every wireless device in the house (iphone, ipad, ps3, laptop, other wireless desktop)
The strangest part is that I did not update or make any changes to the router or its firmware. This just suddenly happened out of nowhere.
Also, the problem isn't consistent. Wifi will be up and running at full speeds, then suddenly it slows down.
I'm not sure if this is a sign of the router dying or if there's something else that I'm missing.
