WNDR4500 AP Cloud Setup Help Please
captfisk
I recently converted my WNDR4500 to an access point which had the cloud service working pretty good when it was my main router. My new main router is the R6300 which allows use of the same drive but no cloud, is there a way to still get the 4500 to use cloud and keep it as an AP what would you recommend.
Cloud service features require internet access.
Netgear will be releasing a firmware update that will allow the r6300 to match the feature set of the 4500. Ill see if I can get you a date when to expect it.
Bob Silver
Netgear AV Consultant
