Wpa2 enterprise or personal
mightyoakbob
I have a bit of a mystery. Inssider reports that my rt-n66u is using wpa2-enterprise and yet the config inside the router is set to wpa2-personal.
Anyone else getting this?
Using 374.36_beta1-sdk5.
Cheers
Bob.
Might want to shut down inssider (and/or even update it...), 'forget' the network, re-associate and check inssider again.
Of course, after verifying once again (a reboot wouldn't hurt either - both laptop and router) in the web gui everything is correct.
If it's still showing the same: this would be reason enough for me to try the latest beta v.2239 from Asus or RMerlin's excellent 374.38_2-em firmwares. :)
P Client connection reporting wpa2 vs wpa3 Asuswrt-Merlin 1
