wpa_supplicant for Rt-AX88U?
busch09
anyone know where I could get a wpa_supplicant for the RT-88U ? I cant figure out how to compile it myself.
No compiling required, it's a text file. And, no different than any other router, it's a generic file.
Example for my Raspberry Pi:
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
country=CA
network={
    ssid="MySSID"
    psk="MyPassword!"
Knowing what platform you are using would be helpful :)
The RT-AX88U will use Broadcom's nas when running in WPA2, and wpa_supplicant when running in WPA3. You cannot override this, this is tied to closed source code.
