WPS for guest network
rampitec
Hi!
I have a really brief question, more a wish list. Is that possible somehow to change WPS function from main network to guest? I usually have no problem entering my password into my own devices and do not have to do it often, but with guests it happen more often and sometimes more troublesome. If I could I would also then change guest password to something more secure.
Thanks,
Stas
Bad wish. :)
Disable WPS entirely.
Enable Guest ssid's instead with a simple password that you randomly change as you wish.
