Wrong access to Download Master with port different to default
Shark6969
Hello:
When I configure the access to the web interface with a different port than default (Administration->System-> HTTPS Lan port), when you try to Access to (USB Aplications->
Download Master) after installing it, is doen’t work.
For example, if you configure the web interface with the port 7887, you’d access with 192.168.69.1:7887
When you try to access to the Download Master, the firmware concatenate the router IP with the port 8081. If you haven’t changed the default web interface port, the access to Download Master is correct, but id you have changed the port, the address built by the router is like 192.168.69.1:7887:8081. Of course, this address can not work.
Code is seen in the picture.
Regards
Try 380.67, Asus fixed some things about that in the 7743 GPL.
Thanks. I'll do as soon as posible because I'm actually out of my house because holidays. I'll keep you updated.
