Wireguard Wrong client Status
nunu
Hello everybody,
I'm facing a minor issue with wg_manager: client status seems not correct.
Router: GT-AC2900
Firmware: 386.14
Scripts: all up to date.
So i have installed wg_manager to configure a wireguard server.
I have created a peer.
The goal is to access to my Home network from internet.
So all is working fine: i can access to the router, and hosts of my home network.
Test is made with an android smartphone with the official wireguard application.
My issue, is the status displayed by wg_manager :
Clients: 0 ??
and if i create some data trafic on the server, the number of Kb is increasing ...
So i would like to know is something could be missed in a configuration to make a client not seen from peer status ?
regards
Clients: 0 ??
If Im not mistaken, that view only shows the router peers summary. Clients = 0 refers to that you have no internet client configs imported (like Surfshark, Proton VPN et.c.). you are only using a server peer and roaming clients are not part of this view.
its been a while since I used wgm, but what do you get from:
E:Option ==> peer wg21
or possibly:
E:Option ==> peer list
