Network Freak 2009
In My home Network I have the following Wired Devices
1.Samsung TV Connects at 100mbps Wired
2.Denon Receiver connects at 100mbps wired
3.Laptop running Windows 7 NIC running at 1.0Gbps
4.Xbox 360 Connects At 100mbps
5.Wireless Laptop
Network Setup
ATT DSL Elite 6.0mbps---->2Wire (Bridged)---->Linksys E4200 Conncted WAN To LAN---->Laptop Xbox 360 Cable Going Back To 2Wire Lan Port ----> Connected To 2Wire Are TV And Receiver
The Model of 2Wire I have which is 2701 HG-B Can Be Bridged so I can use the 2wire Lan Ports also as in my setup above
Wirelessly The Xbox 360 Netflix Works Fine I get HD Streams
Wired is where I have a Strange Issue Xbox 360 Works Fine Until I Turn on the Wired Laptop Xbox 360 Netflix Bars start going down little by little until only one Bar is left when not watching Netflix and on the dashboard disconnects if I have am surfing through my Wired Laptop
Did any one have any Idea what is causing Xbox 360 to slow down when wired laptop is On?
5.Wireless Laptop
Network Setup
