jfreemanak
I have googled the above subject but have not found anyone else with the issue that I have. When my XBox One is connected to my home network via WiFi, the router is stable and will run for days/weeks with no problem. As soon as I connect the XBox One via ethernet cable, the router begins to reset every ~30 minutes. I have tried all different firmware versions, with the exact same results. I have also set a static IP and port forwarding, but no luck. Last night I tried installing a 5 port switch between the router and XBox One, but still the same results.
Does anyone have an idea of what is going on? WiFi works okay, but when I try to play video by UPnP on the XBox One from the storage connected to the router, it will not play over WiFi, but will play when connected by ethernet.
Cheers,
Jared
Cheers,
Jared
