XT8 6600 DEAD ☠️
Ashitson
Hey guys,
I decided to go on the ASUS app to check out my network and check for updates. To my surprise I could only see 4 of my 5 nodes? I walked to my son’s game room to check on the node that wasn’t working. To my surprise no LED light, dead… his pc is hardwired into this node but also has WiFi so he hadn’t notice anything wrong. I tried unplugging it and replugging it in, leaving all the wires out and coming back a couple hours later to still not working. Tried resetting it as well and it’s dead meat. Has anyone had this issue and is it worth taking apart and checking the power supply and fuses to possibly repair it or should I just buy another one? I was using 2 ET8s with this mesh system but everyone said I was causing myself issues and by adding too many degrading my signal. So I took the 2 ET8s out and have been only using 5 XT8s. 1 main and 4 throughout my home, now 4 total.
If you haven’t already, I’d absolutely check the power supply brick first.
Find or borrow one with the same Voltage and preferably current, correct polarity and plug size and test it out. Cheap check.
