I have a new XT8 kit setup with Wired Back-haul. I'm using a CAT 7 cable for the Back-haul. I'm trying to get the 5G-2 band off of it so it can be utilized by my WiFi 6 devices. The node shows no 5G-2 SSID and the Router's 5G-2 keeps bouncing. No devices can connect to it AND have internet access. In the app, under WiFi settings, there is a slider/switch to disable "Dedicated Wireless Back-haul". When I turn that off "Apply" remains grayed-out. If I change something within 5G-2, and the "apply" appears, I hit apply and does its thing but when I go back to it "Dedicated Wireless Back-haul" is still enabled. I can't find any option to turn off "Dedicated Wireless Back-haul" with the web GUI. I have to assume (yeah I know), that I can utilize 5G-2 as a third Band for devices when using a wired Back-haul. I set the priority for Back-Haul to Ethernet and it shows the mesh as being hard-wired. I'm also re-IP'ing from 192.168.50.x to 192.68.1.x (for the sake of all the Static IP devices). Latest Firmware installed.
My SSID's are named as follows (fake names):
2.4 - ABCD1234 (same as my old Router)
5-1 - ABCD1234_5G (same as my old Router)
5-2 - ABCD1234_5G-2 (un-hid and renamed, PW the same as the first 2 bands.)
How do I turn off "Dedicated Wireless Backhaul" for 5G-2? I want to rely 100% on the Wired Back-haul and use the 5G-2 for devices.
I reset both routers and started over twice. I ran setup with both the App and the Web GUI (both guided and advanced setups). My first question is, do I need to establish the Mesh wirelessly first, then connect the back-haul cable (Lan port on the router, WAN port on the node) or can I start the setup/config with it connected? At what point do I un-hide and rename 5G-2?
Any thoughts?
Thanks Guys!
Any thoughts?
Thanks Guys!
