XT8 - possible to use 5GHz-2 in Bridge mode?
preacher65
Hi, question is as per the subject - does anyone know if it's possible to use 5GHz-2 in Bridge mode? It seems to be limited to 5GHz-1 for the bridge.
When I try manual settings for the bridge, and select 5GHz-2, it goes into a mode where the LED flashes blue, which appears to mean it's trying to join a mesh.
Does entering details for the 5GHz-2 network automatically put it into AIMesh mode?
Many thanks
I don't know if that will work or not. I do know that when you put a satellite XT8 in bridge mode, the main unit sees it as a plain old client, not an AIMesh node. So possibly the step you are missing is to configure the main unit to allow client connections on the 5GHz-2 radio. (By default, it'll only allow 5GHz-2 connections for wireless backhaul from AIMesh nodes.)
If you have success, please let us know! (And mention which ASUS firmware version you're using, because it likely matters.)
