I MANAGED TO UNBRICK MY RBS50!
Here's a short description of how I did it.
I turned off Wifi on my PC. (Important to avoid any network issues)
I connected to the RBS50 with the serial console.
I also connected the RBS50 to my PC with an ethernet cable, connected to the LAN port closest to the power connector on the RBS50
Turned on the RBS50
Aborted the boot process when asked to in the serial console.
I then ran fw_recovery in the console and then the RBS50 went into Update mode. (if i remember correctly that's what it was called)
Be careful to notice what IP address and Port the RBS informs that it is listening on when it enters Update mode. It can be 192.168.1.250, or 192.168.1.1 or something else.
Mine was 192.168.1.1 and port 69.
So I gave my PC the IP adress 192.168.1.10 so it is on the same subnet as the RBS
I then uploaded the image with tftp to the address and port the RBS said it was listening on.
After that my RBS50 worked fine again and could sync with the RBR50 router.
Before this I tried a lot with nmrpflash without any success at all.
Turned on the RBS50
