mlai
Hi Gurus!
I had a AiMesh (AP Mode) of 7 XD6/XD6S and they worked fabulous. Wireless throughputs on a 1G Fiber WAN (router is a Edgerouter 6P) can go as high as 950mpbs in both up/down directions according to speedtest.net and fast.com
So just acquired a pair of ET12s to add 2.5G WAN/LAN and 6G capability to my home network for my 6E capable devices (Samsung ZFold3/ZFold4/Tab S8+/Asus Flow X13(2022)/Z13/Zenbook Pro 16X OLED). Oh boy was I disappointed......
Current Setup
A ET12 is setup as the primary node (AP mode) to manage the AiMesh network. Firmware 3.0.0.4.386_48826
Backhaul is all CAT7 connecting to a 10GBe switch. WAN is 1G fiber to a Edgerouter6P which is fully capable of saturating the 1G WAN link.
All the XD6/XD6S and the other ET12 are reconfigured to be managed by the primary ET12 as a single AIMesh network.
Issues
First, the upload speed on 5G/6G when devices are attached to ET12 is only half of what the downlink speed is. For instances, while I can get 900mbps with my devices connecting to the ET12, I only get roughly half that on upload. This is happening on both 5G/6G band with the ET12 nodes. When the devices are connecting to 5G band to any of the XD6/XD6S I can get as high as 950mbps up/down when I am next to the nodes.
Second. May not be entirely Asus's fault but they really oughta sort it out with Samsung. My Samsung ZFold3 and ZFold4 can ONLY CONNECT TO 6GHz NETWORK ON THE PRIMARY NODE. I tried setting up the individual ET12s as standalones and the phones can connect to either unit without problem. As soon as one becomes a node to AiMesh, neither my ZFold3/ZFold4 will connect to the mesh nodes in 6GHz EXCEPT THE PRIMARY NODE.
Third. Maybe my fault. The ET12 unit is huge physically. Which is somewhat of a problem for me in terms of placement amongst furniture. The XD6/XD6S is way easier to place and much more inconspicuous.......
Is there any solution to the slow upload throughput and connectivity issues with Samsung devices?
On the other hand, my Asus laptops uses both Intel Wireless AX211 and MediaTek MT7922 and they both work fine on either 5G/6G band with the ET12. They do suffer the same issue of half uplink throughput the same as the ZFold3/ZFold4.
Current Setup
Issues
