Trying to put all my IOT devices on my guest network and still run pihole on my regular. Everything seems to work fine from the router, but the IOT network will only appear on the mesh node for a few minutes, and then will no longer serve new addresses via DHCP. Yes, I've configured the guest for all mesh nodes. Switching that off then back on seems to make things work for a few minutes, but then new clients no longer get IP addresses. Did a hard reset on the node and that hasn't helped. Anyone else getting this to work consistently?
Oh, forgot to mention everything appears to work fine if I allow the guest network access to my intranet, but then what's the point?
