fairmarketvalue
Ok, I'm stumped. I have a home network comprised of 3 ZenWiFi XT8 units (1 router, 2 nodes), each running the latest official Asus firmware (386.43181). The connection between the router and each of the nodes is excellent, the network is in a "star" layout with each node connected directly to the router via 5 GHz-2 wireless backhaul. I have no Guest network.
One of the nodes (I'll call it the "Kitchen Node") is physically located within 2 feet of a Panasonic WiFi-equipped stereo and about 4 feet from my Nest Smart Thermostat. However, when I access the AiMesh tab on the Asus GUI, the Kitchen Node shows no connected clients. Instead, the Panasonic stereo and Nest Thermostat each are connected via the 2.4 GHz network to the router, which is some physical distance away from those clients. I have tried optimizing the system with no success, as well as reconnecting each client individually to see if either of them would connect with the Kitchen Node, but no joy. Finally, when I try to "bind" on of these clients to the Kitchen Node, I get the following message:
"Your Panasonic is forced to bind to ZenWiFi AX. <br> Due to the current weak connection, your Panasonic might lose its internet connection. Are you sure to proceed? (Cancel/OK)"
Since the connection strength between the router and the Kitchen Node is listed on the AiMesh GUI page as "Great" and the client is so physically close to the node, I have no idea why I am getting such an error message. Should I just ignore the message and bind the client to the node and be done with it, or am I missing something that will adversely affect the rest of my network? Thanks in advance for any suggestions.
