From auto download.
No description.
So far so good.
heheh, i see you couldn't resist finally!
I've had it installed all morning. not a lot of time, but so far so good. I too, would like to see the release notes.argh, frustrating waiting for them to publish on the website.. you notice any difference so far?
this is weird.. i did my very unscientific proximity test and the speed seems capped at 100Mbps.. If I change something, anything in the wifi settings and save then it jumps up to 300+Mbps. If I reboot the routers it starts off at 100Mbps again. very odd. I might do a factory reset later.
every firmware upgrade I've done a factory reset after install as recommended. I don't seem to have this issue though. Everything seems fine for me so far in the very short period it's been up and running.
through the UI. I use the RESTORE functionhmm, do you do a factory reset through the UI or the WPS + power button method?
Do we really need to do a factory reset after every firmware update? It's just a pain in the butt to move the node close to the router again to initiate the connection between the router and the node.
Thank you both!
Welcome To SNBForums
