davekstl
I updated my ISP from 200 to 400 Mbps. So I tested the throughput, the ISP Modem is putting out 467 Mbps. I am testing using an ethernet cable directly from my laptop to the Modem.
When testing the Router using the same method, same laptop, same cable, directly into the Router, my speeds are half of the Modem. Anywhere from 197 ~ 267 Mbps. I expected the same as the Modem, or very close.
So before I panic, can anyone explain what my real expectation should be?
And if the router should be faster, how do I achieve that?
Dave
Dave
