anyone remember Pluto? (pre linuxMCE)
Twice_Shy
I was just curious if anyone here remembered when the Pluto home automation software came out.
I'm told this turned into LinuxMCE(?) but couldn't verify.
The original website seems gone as are the ISO images. I'm wondering if any other projects might've integrated it's code or if there are any features it had that for some reason newer systems did not maintain.
LINUXMCE
Thanks! Does anyone out there have a mirror of the old pluto ISO's by chance? I'm just curious even if it's "obsolete".
Did linuxMCE just continue unbranched as the main and only automation system, or has it split into multiple projects? Have totally separate projects sprouted up with very similar total integration goals? I haven't researched a darn thing since pluto came out a long time ago so i've no clue whats changed in the years.
