asuscomm.com
Paxsat
Salve non riesco piu ad impostare il mio ddns in asuscomm.com ho delle apllicazioni che puntano paxsat.asuscomm.com che non funzionano più come posso fare?
Hi, I can no longer set up my DDNS in asuscomm.com. I have applications pointing to paxsat.asuscomm.com that no longer work. What can I do?
If you had a prior Asus router with the same domain name it needs to be deregistered before you set up a new router.
I had an ac5300 but it broke.. The app doesn't delete the recording if I'm not on WiFi
Avevo un ac5300 ma si è rotto.. L'app non lo fa cancellare la registrazione se non sono in WiFi
If you have the old router available, check this post:
Actually, you don’t need to do that, the old name is not registered anymore in DNS.
Look in the system log for errors from inadyn?
