DDNS Update frequency increase for Asus DDNS
ceephis
I am experiencing a couple of DDNs issues
Currently I am using the ASUS DDNS service (its free and that matters a lotto me right now) but as far as I know it is not updating daily (which is as often as I can seem to set it for on my Asus merlin router.
2 questions.
1. Is there a compatible free DDNs for asus Merlin routers you trust more than the ASUS DDNS?
2. is there a way to increase the refresh rate to an hour or so?
Thanask all for your wisdom and help
1. I use no-ip for my DDNS. it has not let me down in over 8 years with the same domain (unless something happened and I never saw it). I've recently seen a few posts mentioning Asus DDNS having problems.
2.
TThanks so much for this recommendation I'll look into no IP
Here's the option I have for how often to check on my router running Merlin the most updated version for its model which is an rt-ac68r
It'll change if you select noip in the dropdown list. Clearly things are different for Asus DDNS.
