Diversion Email notification error
Kingp1n
Hello I'm setting up email notification
  7. Edit SMTP Server:    smtp-mail.outlook.com
within Diversion and I'm getting the message below:
1. Send testmail
 2. Send testmail, verbose output
 Enter your selection [1-2 e=Exit] 1
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   260    0     0  100   260      0    120  0:00:02  0:00:02 --:--:--   122
curl: (7) Couldn't connect to server
 sending testmail failed
 Note the curl: error above and check your settings
 Press Enter to return to menu
Good thing is I'm still getting the email. Is there another smtp server I should try or just simply ignore the message?
Use option 2 with verbose output to see more details why curl it could not find the server. Check your server port, it should be 587 for outlook.com if I remember correctly.
I re-enabled my email setting notification within Diversion with new SSD. All working well. I forgot about this error but I'm still getting it.
Though I'm still getting the "test" email in my inbox, I wasn't sure if it's a simple fix or just ignore it.
I think you should set them again and not just re-enabling? Port 80 is wrong for sure. Here are my settings if it helps
  1. Edit From address:   .....@outlook.com
  2. Edit To name:        ....
  3. Edit To address:     ....@proton.me
  4. Edit Router name:    RTAX86U
  5. Edit User name:      @outlook.com
  6. Edit Password:       select Edit to view (App password created)
  8. Edit Server port:    587
  9. Edit Protocol:       smtp
 10. Edit SSL flag:       Set to --insecure if curl problems occur
 11. Send testmail to confirm settings
I setup again...this time I used SSL flag '0' vs '5' and this did the trick. I appreciate the response!
