Got the Netgear WNDR3700 - what now?
ReuvenNY
Just got the Netgear WNDR3700 and so far is seems to be a great router. But to really benefit from it's speed and features I know I need the right adapters.
Basically, I need an USB adapter as well as PCI (internal) one.
Netgear makes the WNDA3100. It sells for about $70. I also saw some refurbished for about $25. I didn't find any Dual Band N PCI they make.
My questions are:
1. Is it important to use the same adapter as the router brand?
2. Is the $70 price for the WNDA3100 worth it?
3. Is the refurbished WNDA3100 I should consider?
4. Are there any other Dual Band (2.4/5 GHz) adapters they are inexpensive and recommended?
5. Any other questions I didn't ask that need to be answered?
Thanks for any help.
Reuven
My questions are:
Reuven
No
No
Yes, unless you get a bad refurb
I'm using a cheap Airlink that works well. $19USD shipped.
None that I can think of except for what specs your system is.
netgear forums show a lot of issues w/ the wndr3100 v1....it might be hard to find a refurb v2. i went w/ the linksys wusb600n new open box on ebay on the cheap b/c I specifically wanted a dual ban adapter. Worked like a charm. The WET610n has greater flexibility, but I had trouble with it.
