ComputerSteve
So the log of my router keeps stating this: kernel: MDIO Error: MDIO got failure status on phy 25 .. I'm not noticing any problems but would like to know what that means or how to stop it. Thanks =)
What firmware are you running? You may want to add it to your sig line. What additional services/features do you have enabled? In other words provide more into about your configuration settings and what you have enabled/running on the router.I'm getting the same thing on one of my AX86U Pros after a reboot, perhaps in combo with a firmware update. Massively floods the log. Rebooting again seems to be able to make it stop.
May 5 01:05:09 kernel: libphy: Fixed MDIO Bus: probed
May 5 01:05:09 kernel: brcm-mdio 837ffd00.mdiosf2: switch_mdio_base=0xffffff8008c9dd00
May 5 01:05:09 kernel: brcm-mdio 837ffd00.mdiosf2: registered
Welcome To SNBForums
