Scribe Strange Issue with Scribe / Syslog-NG after Reboot
ScottW
About 3 months ago, I rebooted my AX86U and noticed afterwards that syslog-ng was not logging correctly. The files were simply not being updated. Scribe status showed everything as working. Rather than investigate, I just did a scribe restart and the logging began working fine again.
The next time I rebooted (about 2 months ago), I again noticed syslog-ng was not updating files after the reboot. As before, Scribe status showed everything was fine, and a scribe restart fixed the problem.
I noticed it again this week, so I started investigating. I *think* I found the problem -- which is that (2) instances of syslog-ng are running after boot (I assume they are fighting over the message sources). But I can't figure out how it is getting started twice.
I added some ps | grep syslog-ng >>/jffs/testlog.log statements to services-start and firewall-start. At services-start time, there was no instance of syslog-ng. At firewall-start, there was still no syslog-ng process running. About 25 seconds later, there was a second firewall-start event -- and at that point, there were TWO syslog-ng processes (plus the two service supervisor processes) running.
 3393 admin    13356 S    {syslog-ng} supervising syslog-ng
 3394 admin     374m S    syslog-ng
 3448 admin    13356 S    {syslog-ng} supervising syslog-ng
 3450 admin     344m S    syslog-ng
Executing a scribe restart command killed both of those and created a single new syslog-ng process (plus the supervising process). After that, everything worked correctly (until the next reboot).
I uninstalled scribe and syslog-ng, using the uninstall command on the scribe menu. Rebooted, and there was no syslog-ng process running. Used AMTM to reinstall Scribe, with the default configuration. Rebooted, and the duplicate syslog-ng is back! As before, scribe restart kills both of them, starts up a new one, and everything works fine again.
What could be causing syslog-ng to be started twice? I have looked through all files in /jffs/scripts, looking for any reference to scribe or syslog-ng. The only relevant call is in service-event, where it belongs.
There's nothing in /etc/init.d calling scribe or syslog-ng. In /opt/init.d, I have rc.func.syslog-ng and S01syslog-ng files, both of which are freshly replaced by today's re-install of Scribe. Nothing else there seems to reference syslog-ng.
Any ideas what is happening here, or how to track it down?
I also see multiple instances of these processes. Is that normal?
 7084    admin     3424     S N      {taildnstotal-ca} /bin/sh /jffs/addons/uiDivStats.d/taildns.d/taildnstotal-cache
7105    admin     3424     S N      {taildnstotal-ca} /bin/sh /jffs/addons/uiDivStats.d/taildns.d/taildnstotal-cache
9529    admin     3556     S        {uiDivStats} /bin/sh /jffs/scripts/uiDivStats querylog
16155    admin     3556     S        {uiDivStats} /bin/sh /jffs/scripts/uiDivStats querylog
19540    admin     3556     S        {uiDivStats} /bin/sh /jffs/scripts/uiDivStats querylog
29162    admin     3556     S        {uiDivStats} /bin/sh /jffs/scripts/uiDivStats querylog
You could try the gamma, but check the prerequisites first regarding syslog.log location and symlink.
Update...
I did a backup of the USB drive and set it up again with amtm. Before, it was two partitions: partition-1 was 80gb ext4, and partition-2 was unformatted. This time I set it up as one ext 4 partition using the entire drive. Used amtm to create the 4gb swap file, as before, then restored the backup.
After a reboot... Only a single syslog-ng process, and syslog-ng is logging properly. Not really sure if it was something about the empty partition, or maybe something else amiss with the formatting -- but it seems to be operating much better now!
It's strange though, that I have two syslog-NG processes with one sticking on zero runtime, yet no such errors.
Glad you found your solution
It's strange though, that I have two syslog-NG processes with one sticking on zero time, yet no such errors.
Well... My linux knowledge is really limited, so I could be off base here but...
I *think* the "white" line in your 'htop' snapshot is the main process -- and the "green" line(s) are worker threads. So, you have only (1) main process, and (1) worker thread. If you run "ps | grep "syslog-ng", it will only show the main process (pid=10356).
The problem I had was (2) main syslog-ng processes, i.e., (2) of the "white" syslog-ng lines. When I ran ps | grep "syslog-ng", it returned (2) main syslog-ng processes (and two of the supervisors).
I still can't figure out what was causing that -- or why a backup/reformat/restore would stop it, when uninstalling/reinstalling scribe and syslog-ng had no effect.
Thanks for the clarity. I wasn't particularly worried about it as it's running fine, just pointing out the two processes as you had explained.
Mysteries, gotta love them.
