Adguard DNS buffer size too small
I missed the woolly mammoths as well. I only know Manny from the Ice Age movie. 😒
I have setup Adguard and Skynet with mostly default settings and everything is functioning very well. I checked my syslog and have been seeing occasional errors from adguard
Use one or the other - Adguard or Skynet - you don't need both as they serve the same purpose..
Ah i thought cache was going to a file on ssd here is my stats
Cpu temp seems a bit high to me tho
Fortunately adguardhome would never need that much cache space hence why your ram isn't all the way used up yet. AdGuardHome will only use up more ram as the cache becomes full. If you did have a big enough user-base that required a cache that big, you would have to run that adguardhome on somewhere other than your router.
i think there is still something wrong in the deep heart of the router
idle latency just went up from 20ms /16ms during a speedtest to 40+ ms
May 8 10:00:26 spdMerlin: Connection quality - Idle Latency: 46.64 ms (jitter: 3.20ms, low: 44.96ms, high: 48.67ms) - Packet Loss: 0.0%
i also see this line
May 8 10:00:15 kernel: sched: RT throttling activated
Try creating a new thread then. Those issues have more to do with your line connection not debug messages coming from your DNS server.
hey i now have more and more dns buffer size to small and some dns lookups take over 100ms how to solve this is there any setting i can change via ssh
