AirMesh with RTAX88U Pro and RT-AX53U
mrlordziemniak
I have rt-ax88u pro setup to airmesh with rt-ax53u and everything is working, when i install merlin to rt-ax88u pro -> RT-AX88U_PRO_3004_388.7_0 airmesh stop working, it can't find airmesh node, when i install stock asus firmware everything started to work as normal
rt-ax53u is connected by ethernet cable to rt-ax88u
any ideas how to fix this?
after changing firmware at main router yo should factory reset node - if it will still not work factory reset for main and node
AiMesh perhaps?
When changing main router firmware from stock Asuswrt 3.0.0.6 to Asuswrt-Merlin 3.0.0.4 you have to start from scratch. Factory reset, manual configuration.
