[ASUS AX86U Merlin] Blink Sync Module does not connect (connects to iphone hotspot)
dasusm
I have a brand new blink sync module 2 which requires 2.4G WIFI
And I have Merlin running on Asus AX86U-PRO
It does not connect to any AX86u-pro's SSIDs (tried regular 2.4 with legacy support enabled, tried guest 2.4 with very simple passwords)
Looking at the log, I do see there is some activity but the module does not connect. It successfully connects to my Iphone's hotspot (I've only run hotspot with maximize compatibility selected)
MAC of the module is 00:03:7F:F0:91:B3
Feb 22 03:10:35 hostapd: wl0.2: STA 00:03:7f:f0:91:b3 WPA: pairwise key handshake completed (RSN)
Feb 22 03:10:45 wlceventd: wlceventd_proc_event(645): wl0.2: Deauth_ind 00:03:7F:F0:91:B3, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Feb 22 03:10:45 hostapd: wl0.2: STA 00:03:7f:f0:91:b3 IEEE 802.11: disassociated
Feb 22 03:10:45 wlceventd: wlceventd_proc_event(662): wl0.2: Disassoc 00:03:7F:F0:91:B3, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Feb 22 03:10:47 wlceventd: wlceventd_proc_event(685): wl0.2: Auth 00:03:7F:F0:91:B3, status: Successful (0), rssi:0
Feb 22 03:10:47 wlceventd: wlceventd_proc_event(722): wl0.2: Assoc 00:03:7F:F0:91:B3, status: Successful (0), rssi:-49
Feb 22 03:10:47 hostapd: wl0.2: STA 00:03:7f:f0:91:b3 IEEE 802.11: associated
Feb 22 03:10:47 hostapd: wl0.2: STA 00:03:7f:f0:91:b3 RADIUS: starting accounting session 922865BE80E7B890
Feb 22 03:10:47 hostapd: wl0.2: STA 00:03:7f:f0:91:b3 WPA: pairwise key handshake completed (RSN)
Feb 22 03:10:55 kernel: DROP IN=br1 OUT=br0 MAC=08:bf:b8:45:de:31:00:35:ff:22:ab:25:08:00 SRC=192.168.101.254 DST=8.8.8.8 LEN=84 TOS=0x00 PREC=0x00 TTL=63 ID=9648 DF PROTO=ICMP TYPE=8 CODE=0 ID=18453 SEQ=0 MARK=0x2e
Feb 22 03:10:56 kernel: DROP IN=br1 OUT=br0 MAC=08:bf:b8:45:de:31:00:35:ff:22:ab:25:08:00 SRC=192.168.101.254 DST=8.8.8.8 LEN=84 TOS=0x00 PREC=0x00 TTL=63 ID=9669 DF PROTO=ICMP TYPE=8 CODE=0 ID=18453 SEQ=1 MARK=0x2e
Feb 22 03:11:13 kernel: DROP IN=eth0 OUT= MAC=01:00:5e:00:00:01:02:cc:00:00:00:00:08:00 SRC=0.0.0.0 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=54679 OPT (94040000) PROTO=2 MARK=0x8000000
Feb 22 03:11:41 kernel: DROP IN=br1 OUT=br0 MAC=08:bf:b8:45:de:31:00:35:ff:22:ab:25:08:00 SRC=192.168.101.254 DST=8.8.8.8 LEN=84 TOS=0x00 PREC=0x00 TTL=63 ID=12999 DF PROTO=ICMP TYPE=8 CODE=0 ID=6934 SEQ=0 MARK=0x2e
Feb 22 03:11:42 kernel: DROP IN=br1 OUT=br0 MAC=08:bf:b8:45:de:31:00:35:ff:22:ab:25:08:00 SRC=192.168.101.254 DST=8.8.8.8 LEN=84 TOS=0x00 PREC=0x00 TTL=63 ID=13099 DF PROTO=ICMP TYPE=8 CODE=0 ID=6934 SEQ=1 MARK=0x2e
Feb 22 03:12:26 kernel: DROP IN=br1 OUT=br0 MAC=08:bf:b8:45:de:31:00:35:ff:22:ab:25:08:00 SRC=192.168.101.254 DST=8.8.8.8 LEN=84 TOS=0x00 PREC=0x00 TTL=63 ID=21256 DF PROTO=ICMP TYPE=8 CODE=0 ID=61718 SEQ=0 MARK=0x2e
Feb 22 03:12:27 kernel: DROP IN=br1 OUT=br0 MAC=08:bf:b8:45:de:31:00:35:ff:22:ab:25:08:00 SRC=192.168.101.254 DST=8.8.8.8 LEN=84 TOS=0x00 PREC=0x00 TTL=63 ID=21424 DF PROTO=ICMP TYPE=8 CODE=0 ID=61718 SEQ=1 MARK=0x2e
Feb 22 03:12:33 wlceventd: wlceventd_proc_event(645): wl0.2: Deauth_ind 00:03:7F:F0:91:B3, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Feb 22 03:12:33 hostapd: wl0.2: STA 00:03:7f:f0:91:b3 IEEE 802.11: disassociated
Feb 22 03:12:33 wlceventd: wlceventd_proc_event(662): wl0.2: Disassoc 00:03:7F:F0:91:B3, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Feb 22 03:12:36 wlceventd: wlceventd_proc_event(685): wl0.2: Auth 00:03:7F:F0:91:B3, status: Successful (0), rssi:0
Feb 22 03:12:36 hostapd: wl0.2: STA 00:03:7f:f0:91:b3 IEEE 802.11: associated
Feb 22 03:12:36 wlceventd: wlceventd_proc_event(722): wl0.2: Assoc 00:03:7F:F0:91:B3, status: Successful (0), rssi:-46
Feb 22 03:12:36 hostapd: wl0.2: STA 00:03:7f:f0:91:b3 RADIUS: starting accounting session CC68CC0AEEF44FED
Feb 22 03:12:36 hostapd: wl0.2: STA 00:03:7f:f0:91:b3 WPA: pairwise key handshake completed (RSN)
Feb 22 03:13:08 kernel: DROP IN=br1 OUT=br0 MAC=08:bf:b8:45:de:31:00:35:ff:22:ab:25:08:00 SRC=192.168.101.254 DST=8.8.8.8 LEN=84 TOS=0x00 PREC=0x00 TTL=63 ID=21509 DF PROTO=ICMP TYPE=8 CODE=0 ID=48663 SEQ=0 MARK=0x2e
Feb 22 03:13:09 kernel: DROP IN=br1 OUT=br0 MAC=08:bf:b8:45:de:31:00:35:ff:22:ab:25:08:00 SRC=192.168.101.254 DST=8.8.8.8 LEN=84 TOS=0x00 PREC=0x00 TTL=63 ID=21540 DF PROTO=ICMP TYPE=8 CODE=0 ID=48663 SEQ=1 MARK=0x2e
Feb 22 03:13:18 kernel: DROP IN=eth0 OUT= MAC=01:00:5e:00:00:01:02:cc:00:00:00:00:08:00 SRC=0.0.0.0 DST=224.0.0.1 LEN=36 TOS=0x00
