Asus Tuf ax4200 router log
bwana_
So I have a brand new Asus Tuf AX4200 router with the latest firmware installed.
I just want to confirm this nvram_free I saw from time to time displaying in the log just after I made a change to the router settings. Is this normal? Never seen this before on my other Asus routers I had before
That's absolutely normal for routers using the MediaTek SOC, I see the same message on RT-AX59U.
Have a similar question regarding a TUF-AX4200. After blocking a MAC address in WiFi settings, the log file is flooded with messages like this:
"Feb 24 09:29:01 kernel: 7986@C08L1apclix0,ap_peer_auth_req_at_idle_action() 840: Failed in BL/ACL 0/1 checking => send an AUTH seq#2 with Status code = 1exit"
Is it the expected behavior?
