Release ASUS TUF-AX5400 Firmware version 3.0.0.4.388_24121
nickie
Version 3.0.0.4.388_24121
94.99 MB
2023/10/09
Bug Fixes and Enhancements
- Fixed WAN Connection Issue.
- Fixed cannot access WireGuard Server if enable DMZ.
- Fixed DDNS server error occurs when registering DDNS with app.
- Resolved an issue that caused hostname errors in the DDNS service.
- NowTV profile has been added under new IPTV profiles.
- IPTV settings have been updated for better compatibility with Unifi Biz VoIP service.
- Fixed v6plus-Related Issues and.
- Resolved OpenVPN Server TAP Mode Issue.
- Fixed ipv6 network service filter not work.
- Fixed the problem that the Aicloud app cannot add router on Android 9.
Security Fixes
- Fixed several curl vulnerabilities including CVE-2021-27218, CVE-2021-27219, CVE-2023-28322, CVE-2023-28321, CVE-2023-28319, CVE-2023-32643.
- Fixed FFmpeg vulnerabilities, specifically CVE-2022-3964, CVE-2022-48434, and CVE-2022-3109.
- Corrected an OpenVPN vulnerability categorized as CWE-134.
- Strengthened protection against SSH brute force attacks.
- Updated OpenSSL to 1.1.1t for vulnerabilities.
Please unzip the firmware file, and then verify the checksum.
SHA256: 533fe4269875379895920e1f3bdbbad60e86a670e9894e50920a071db3917fd9
Download link
Yes, not all issues are observed by all users.
And, not all fixes are listed either, for all firmware releases.
I see still decrease free available RAM. 6 days from restart from 76% to 81%, each day 1%...
I wait what will happen...
Screenshot 2023-10-22 at 17-11-37 ASUS Wireless Router TUF-AX5400 - Mapa sieci.png
I have Attached HDD drive on the USB port. I noticed that with the latest version there is no USB hibernation option. Why they have removed it (under Administration, System).
Don't know - I assume it was creating problems (e.g. not going to sleep and/or not waking up).
Yeah, they have replaced the manual timer to the automatic one. I haven't yet counted how long it takes to put USB to sleep.
Absolutely bad, that I cannot keep the USB port always on now. Every time I want to access the drive, I have to wait about 7-10 seconds.
I'm very curious what will happen next...
Screenshot 2023-11-17 at 23-07-24 ASUS Wireless Router TUF-AX5400 - Ogólny log.png
Screenshot 2023-11-17 at 23-08-02 ASUS Wireless Router TUF-AX5400 - Mapa sieci.png
Nov 17 05:19:13 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7948)]do webs_update
Nov 17 05:19:39 WATCHDOG: [FAUPGRADE][auto_firmware_check:(8016)]could not retrieve firmware information: webs_state_update = 1, webs_state_error = 1, webs_state_dl_error = 0, webs_state_info.len = 23
Nov 17 05:20:08 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7948)]do webs_update
Nov 17 05:21:03 WATCHDOG: [FAUPGRADE][auto_firmware_check:(8016)]could not retrieve firmware information: webs_state_update = 1, webs_state_error = 1, webs_state_dl_error = 0, webs_state_info.len = 23
Nov 17 05:21:32 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7948)]do webs_update
Nov 17 05:21:58 WATCHDOG: [FAUPGRADE][auto_firmware_check:(8016)]could not retrieve firmware information: webs_state_update = 1, webs_state_error = 1, webs_state_dl_error = 0, webs_state_info.len = 23
Like Igs said, most likely, nothing. That log item is fairly common. I think you get that if you disable auto-update or the update server is down/unreachable.
Router works 58 days without restart.
Used RAM is between 73 - 94%. One or two days was small problems with stability connections WAN (20-30 second) next all services back to normal. Log was Clear.
I had a day off and decided to catch up on movies.
After watching Disney+ for a long time, the router became unstable. He broke the connection first with his wife's mobile phone (3m from the router), then with Chromecast (No Wi-Fi connection), distance from the router 0.3 m. The connection returned on its own after about a minute.
I checked again,
Problem occurs when watching movies takes more than a few hours.
Router has problem with WiFi connection, it is unstable.
  • syslog(2).txt
There is something seriously wrong with the service LOG.
It shows that there are 23 hours of registration left and it has been running for over a day... 😊
Please compare:
- log duration
- system clock
The router lost access to the Internet and severed all connections. He recovered after about a minute.
  • syslog(8).txt
