RMerlin
Asuswrt-Merlin dev
Asuswrt-Merlin 3004.388.4 beta is now available. Note that starting with this release, the version numbering scheme was changed to better illustrate that this is based on the 3.0.0.4 code (versus 3.0.0.6 that would be 3006.102.x). Also as mentionned a few months ago, the RT-AX56U is no longer supported as of this release. The last three 388.x releases for that model were already based on unreleased code as Asus never moved that model to the 388 codebase. They have now officially added that model to their End of Life list recently.
August 15th, 2023: Beta 3 is now available. Changes since beta 2:
August 4th, 2023: Beta 2 is now available. Changes since beta 1:
Changes since 388.3/388.2_2:
Downloads are here.
Changelog is here.
a58ac601af (HEAD -> master, origin/master) Updated documentation
afab150ab6 rc: Samba was getting restarted twice in a row in wan_up() due to duplicate code
987521103d qca-ar3k-fw: Added missing bluetooth firmware for XT12
8df077d52f rc: move ovpn nvram reset to init_nvram() to better match upstream
8745bb4eae rc: update ntpd sync events to reflect upstream changes to ntpclient sync events
3a5ea653f6 rc: restart DDNS on WAN interface going up again as before 23588 merge
9e01e85092 shared: ping_target_with_size() child should exit once done
a184dacb11 rc: fix bad merge
d0db77362e Bumped revision to beta 3
3616499f54 HND5.04: fix missing ethctl userspace tool
e401469c2b rc: mount WAN interface before adjusting its MTU
78a92dc997 (HEAD -> master, origin/master) rc: reverted ddns IP check to upstream method; fixed a few bad code merges
6a31004700 rc: re-harmonize with upstream, fixing a few bad merged sections
a6a9a8fd38 rc: reset attempt counter on successful custom DDNS update
3a9f7a5598 rc: set ddns WAN unit variable on successful custom DDNS update
c013705bf1 httpd: only skip querying channel utilization on non-dhd SoC if on SDK 5.02L07P2
3d1c9bf151 Bumped revision to beta 2
3004.388.4 (xx-xxx-xxxx)
- NOTE: In preparation for the new 3.0.0.6 codebase, the version
string will now start with 3004 or 3006 to match with
upstream.
- NOTE: The RT-AX56U is no longer supported, as Asus has put it
on End-of-Life status, and the previous Asuswrt-Merlin
388 releases for that model were all based on untested
code.
- NEW: Display channel utilisation for supported platforms on the
Wireless Log page.
- UPDATED: Merged GPL 388_23588.
- UPDATED: curl to 8.1.2.
- UPDATED: OpenVPN to 2.6.5.
- UPDATED: openssl to 1.1.1u.
- UPDATED: tor to 0.4.7.13.
- CHANGED: FTP server will now only support strong ciphers
in TLS mode.
- FIXED: QOS Classification showing no Upload data on some
WAN configurations.
- FIXED: Radio temperature graphs weren't updating
- REMOVED: Ethernet port status from the Tools Sysinfo page
(as this is redundant with Asus' own display
now available on the networkmap page).
Downloads are here.
Changelog is here.
