Asuswrt-Merlin 380.59 is now available
I did a factory reset and all settings left on default. When I flashed firmware 380.59 thats when the 5ghz led stopped staying on after a reboot but the 5ghz WiFi is working if I flash a older firmware like the last one the led would stay on after a reboot it's like some setting is not serveing the reboot or not serveing thank you for your reply sir
The order of operations is:
Flash new firmware to the unit.
Perform a reset to factory defaults.
http://www.snbforums.com/threads/no...l-and-manual-configuration.27115/#post-205573
380.59 drops media streaming services after a while. 380.58 does not have this issue.
Try the 380.60 alpha 3 beta if your model is supported. It includes changes to minidlna related to broadcasts.
"Routing conflict error" warning is back in this release, it was solved in 380.58,
if I switch OpenVPN (Client) On/Off with IPVanish.
Hope it will be gone in .60 version.
Folks with SMB connectivity issues, try the following smb.postconf:
#!/bin/sh
CONFIG=$1
source /usr/sbin/helper.sh
pc_insert "[global]" "client use spnego = no" $CONFIG
Windows 7 + Windows Live Essentials tend to mess up with SMB authentication. I thought the issue had been resolved in Samba 3.5.6, but it's possible that it could still be problematic. This would disable the incompatible handshaking support.
sometimes when I click traffic analyser my whole GUI seems to fail, even trying to access login page from another device it just loads forever. requires a reboot to sort, anyone else seen this happening? ac68u.
when this happens no traffic data is logged but internet remains up for all devices
Just upgraded from an RT-N66U to an RT-AC68U HW REV A2 with this firmware 380.59 and been having troubles with an external hard disk.
I've tried with the option "Reducing USB 3.0 interference" enabled and disabled and also connecting the hard disk to the USB 2.0 port but he stops responding to samba requests and also to DLNA requests.
The log when I plug the router and access the Samba I get the following log:
"Jun 19 12:23:30 kernel: usb 1-1: new SuperSpeed USB device using xhci_hcd and address 2
Jun 19 12:23:30 kernel: xhci_hcd 0000:00:0c.0: WARN: short transfer on control ep
Jun 19 12:23:30 kernel: xhci_hcd 0000:00:0c.0: disable burst on ep 1
Jun 19 12:23:30 kernel: xhci_hcd 0000:00:0c.0: WARN no SS endpoint bMaxBurst
Jun 19 12:23:30 kernel: xhci_hcd 0000:00:0c.0: disable burst on ep 2
Jun 19 12:23:30 kernel: scsi0 : usb-storage 1-1:1.0
Jun 19 12:23:31 kernel: scsi 0:0:0:0: Direct-Access ST3000DM 001-1CH166 CC47 PQ: 0 ANSI: 6
Jun 19 12:23:31 kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Jun 19 12:23:31 kernel: sd 0:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
Jun 19 12:23:31 kernel: xhci_hcd 0000:00:0c.0: WARN: Stalled endpoint
Jun 19 12:23:31 kernel: sd 0:0:0:0: [sda] 5860533168 512-byte logical blocks: (3.00 TB/2.72 TiB)
Jun 19 12:23:31 kernel: sd 0:0:0:0: [sda] Write Protect is off
Jun 19 12:23:31 kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Jun 19 12:23:31 kernel: sda: sda1 sda2
Jun 19 12:23:31 kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Jun 19 12:23:31 hotplug[1301]: USB /dev/sda1(unknown) failed to mount at the first try!
Jun 19 12:23:31 usb: USB /dev/sda1(unknown) failed to mount At the first try!
Jun 19 12:23:31 kernel: tfat: fail_safe is enabled
Jun 19 12:23:31 kernel: tntfs info (device sda1, pid 1310): ntfs_fill_super(): fail_safe is enabled
Jun 19 12:23:32 hotplug[1299]: USB /dev/sda2(ntfs) failed to mount at the first try!
Jun 19 12:23:32 usb: USB /dev/sda2(ntfs) failed to mount At the first try!
Jun 19 12:23:32 kernel: tntfs info (device sda2, pid 1334): ntfs_fill_super(): fail_safe is enabled
Jun 19 12:23:32 kernel: tntfs info (device sda2, pid 1334): load_system_files(): NTFS volume name 'Verbatim HDD', version 3.1 (cluster_size 4096, PAGE_CACHE_SIZE 4096).
Jun 19 12:23:33 syslog: USB ntfs fs at /dev/sda2 mounted on /tmp/mnt/Verbatim_HDD
Jun 19 12:23:33 usb: USB ntfs fs at /dev/sda2 mounted on /tmp/mnt/Verbatim_HDD.
Jun 19 12:23:33 rc_service: hotplug 1299:notify_rc restart_nasapps
Jun 19 12:23:34 iTunes: daemon is stopped
Jun 19 12:23:34 FTP Server: daemon is stopped
Jun 19 12:23:34 Samba Server: smb daemon is stopped
Jun 19 12:23:34 kernel: gro disabled
Jun 19 12:23:35 Timemachine: daemon is stopped
Jun 19 12:23:35 miniupnpd[720]: shutting down MiniUPnPd
Jun 19 12:23:35 kernel: gro enabled with interval 2
Jun 19 12:23:37 Samba Server: daemon is started
Jun 19 12:23:37 kernel: RPC: Registered udp transport module.
Jun 19 12:23:37 kernel: RPC: Registered tcp transport module.
Jun 19 12:23:37 kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
Jun 19 12:23:37 kernel: Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
Jun 19 12:23:37 statd[1387]: Version 1.1.6 Starting
Jun 19 12:23:37 statd[1387]: statd running as root. chown /var/lib/nfs/sm to choose different user
Jun 19 12:23:37 kernel: svc: failed to register lockdv1 RPC service (errno 97).
Jun 19 12:23:39 miniupnpd[1402]: HTTP listening on port 35966
Jun 19 12:23:39 miniupnpd[1402]: Listening for NAT-PMP/PCP traffic on port 5351
Jun 19 12:24:58 kernel: __find_get_block_slow() failed. block=5517221896, b_blocknr=1222254600
Jun 19 12:24:58 kernel: b_state=0x00000020, b_size=512
Jun 19 12:24:58 kernel: device blocksize: 512
Jun 19 12:24:58 kernel: device blocksize: 512"
This last part with of kernel log repeats itself lots of time when we try to access samba.
On the top activity I get samba consuming the bigger part of CPU:
Mem: 102552K used, 153148K free, 0K shrd, 1080K buff, 40400K cached
CPU: 2.2% usr 50.6% sys 0.0% nic 46.1% idle 0.0% io 0.0% irq 0.8% sirq
Load average: 4.01 3.15 1.89 3/105 2616
PID PPID USER STAT VSZ %VSZ CPU %CPU COMMAND
1486 1374 nobody R 5976 2.3 1 22.9 /usr/sbin/smbd -D -s /etc/smb.conf
1733 1374 nobody R 5972 2.3 1 22.9 /usr/sbin/smbd -D -s /etc/smb.conf
282 2 admin SW 0 0.0 1 3.9 [kworker/1:1]
355 1 admin S 1384 0.5 0 0.7 /sbin/klogd -c 5
449 1 admin S 6568 2.5 0 0.2 httpd -i br0
742 741 admin S 2032 0.7 0 0.2 wred -B
When checking on the GUI the CPU 2 is at 100% and when I try to access samba again it says on windows explorer that "Insuficient resources exist to complete the requested service".
After this happens the router gets very slow and after a short while it hangs and stops responding to requests from wired and wireless connections.
I also get the following error on dlna log:
"[2016/06/16 07:47:37] scanner.c:615: error: Error creating SQLite3 database!
[2016/06/16 07:47:37] minidlna.c:385: fatal: ERROR: Failed to create sqlite database! Exiting...
[2016/06/19 12:23:41] minidlna.c:1205: warn: Starting MiniDLNA version 1.1.5.
[2016/06/19 12:23:42] minidlna.c:363: warn: Creating new database at /tmp/mnt/Verbatim_HDD/.minidlna/files.db
[2016/06/19 12:23:42] sql.c:41: error: SQL ERROR 1 [table OBJECTS already exists]
CREATE TABLE OBJECTS (ID INTEGER PRIMARY KEY AUTOINCREMENT, OBJECT_ID TEXT UNIQUE NOT NULL, PARENT_ID TEXT NOT NULL, REF_ID TEXT DEFAULT NULL, CLASS TEXT NOT NULL, DETAIL_ID INTEGER DEFAULT NULL, NAME TEXT DEFAULT NULL);
[2016/06/19 12:23:42] scanner.c:615: error: Error creating SQLite3 database!
[2016/06/19 12:23:42] minidlna.c:385: fatal: ERROR: Failed to create sqlite database! Exiting..."
This is very strange as this disk has been working perfectly on the RT-N66U with John's fork for some years.
Can anyone help?
I just wanted to add that the disk that gives problems is a 3TB 3.5" USB3.0 Seagate formated with NTFS and I've tried several USB memory sticks formated with FAT32 without any problems.
Can someone please tell me if you have encountered any DDNS registering error (asuscomm.com) after .59?
Thank you.
Thank you.
Nope, not at all. I just upgraded from an RT-N66U (380.58) to an RT-AC68R (380.59). I renamed my asuscomm DDNS on the old router, made sure it registered successfully, then logged into the new router and registered my original address. Took less than 10 seconds.
I get: request error. please try again...
I am not changing routers, just new firmware and when i try to register DDNS i get that error.
Even if i try with a totally new and different name.
Asus's DDNS service is frequently down. I recommend switching to a different DDNS provider.
Can anyone help?
@RMerlin
Any idea on this problem??
@RMerlin
Sorry to bother you again. Any other idea to try on the DDNS issue with 87U? I have logged from the same internet connection using my RT-68U and the asus server responds instantly. When i am trying from 87U it says "applying settings" and stays there forever. Once i reload the page the answer is "request error. please try again later"
@RMerlin
As I said, try a different DDNS service provider.
For the past couple of weeks the Network Map wasn't loading all of a sudden. I go to Tools > Sysinfo, go down to Ethernet Ports and find this message: 'Querying switch...' Everything plugged into the Ethernet ports and the router itself works fine otherwise. There's days where it queries the switch fine and shows what's plugged in along with the Network Map like normal, other times it goes back to that message. Any ideas what's going on?
For the past couple of weeks the Network Map wasn't loading all of a sudden. I go to Tools > Sysinfo, go down to Ethernet Ports and find this message: 'Querying switch...' Everything plugged into the Ethernet ports and the router itself works fine otherwise. There's days where it queries the switch fine and shows what's plugged in along with the Network Map like normal, other times it goes back to that message. Any ideas on what's going on?
You have a device with an invalid name causing Javascript errors. Open your web browser console, and look at the line containing the error - it should tell you what device name is breaking it. Typically, it's caused by devices with quotes in their names.
Thing is, I've been using the same names for the past year and a half I've had this router without issue until now, initially with stock firmware and from 378.51 to 380.59. There's 3 names that use apostrophes but that's it.
Remove the apostrophes.
I might have just missed this before, but my AC66U is dropping the 2.4Ghz band with 380.59. I notice(d) it now because my Philips Fidelio speakers are unable to connect to my home network (these don't work on the 5 Ghz band which is still available for my iPhone and iPad). My current workaround is to reboot the router.
What else can I do or should I try?
I also just noticed this:
wl0_country_code=EU
wl_country_code=US
wl1_country_code=EU
I have never tinkered with these settings and I have no intention to, as I want to make sure that I follow the appropriate (EU) laws. However, the set currently seems inconsistent to me. Should the "wl_country_code" not also be "EU" instead of "US"? If so, (how) can I (safely) change that?
Also weird: OS X El Capitan's Wireless Diagnostics lists the country as FR while I don't live in France.
