jz87
Very green when it comes to networking so I apologize if this has been answered... I've been looking online extensively and so far, all I've been able to internalize is that the DROP warnings are good/expected/the result of my firewall.
I noticed a few issues with performance after changing to public DNS etc. (post Merlin flash) so I took a look at the system logs thinking I'd know what to do and.... I didn't. I've copied portions out below.
So like I noted, the DROPS are - it seems - good.
But it's this stuff that's giving me the heebee jeebies (extracted from the below small portsion of the log):
Similar entries also said something about starting my VPN on its own... which wasn't cool:
Oh, and dumb thing I did in case it could cause any issues: tried installing some addons without having installed entware so the all failed... and the AMTM screen says skynet is still there, even after i used the uninstall commands/scripts like I've seen posted.
Anyways... any insight/help/advice would be appreciated.... legit at the point where I can't even understand the answer if I already stumbled upon it so gonna beg for some grace here.
THANK YOU.
Small portion of log/info below;
May 18 20:38:31 custom_script: Running /jffs/scripts/service-event-end (args: restart logger)
May 18 20:38:47 rc_service: httpd 4189:notify_rc restart_logger
May 18 20:38:47 syslogd exiting
May 18 20:38:47 syslogd started: BusyBox v1.25.1
May 18 17:40:18 rc_service: httpd 4189:notify_rc start_wgc 1
May 18 17:40:18 kernel: wireguard: WireGuard 1.0.20210124 loaded. See www.wireguard.com for information.
May 18 17:40:18 kernel: wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
May 18 17:40:19 WireGuard: Starting client 1.
May 18 17:40:19 custom_script: Running /jffs/scripts/service-event-end (args: start wgc)
May 18 17:40:19 dnsmasq[4489]: read /etc/hosts - 24 names
May 18 17:40:19 dnsmasq[4489]: using nameserver 127.0.1.1#53
May 18 17:40:19 dnsmasq[4489]: using only locally-known addresses for _dns.resolver.arpa
May 18 17:40:19 dnsmasq[4489]: using only locally-known addresses for use-application-dns.net
May 18 17:40:22 rc_service: httpd 4189:notify_rc restart_vpnrouting0
May 18 17:40:22 vpndirector: Routing MTL from 10.0.0.2 to any through wgc1
amtm 3.7 FW by thelonelycoder
RT-AX58U (armv7l) FW-388.2 @ 10.0.0.1
Operation Mode: Wireless router
The Asuswrt-Merlin Terminal Menu
2 open Skynet v7.4.1
vp open VPNMON-R2 v
rt open RTRMON v1.55
i show all available scripts or tools
u check for script updates
amtm options
e exit t theme r reset a about
_____________________________________________
Enter option
THANK YOU.
UTC 2023 merlin@f4e3563 | |
Bootloader (CFE) | 0.1.0.7 |
Wireless Driver Version | wl0: Feb 16 2023 03:02:51 version 17.10.157.2809 (r801046) f085068 wl1: Feb 16 2023 03:04:25 version 17.10.157.2809 (r801046) f085068 FWID 01-191b00 |
Features | 11AX 2.4G 5G HTTPS PARENTAL2 WIFI_LOGO account_binding acl96 alexa am_addons amas app appnet bcmhnd bcmwifi betaupg bwdpi cake cfg_sync cfg_wps_btn cloudsync conndiag dhdlog dis11b diskutility dnsfilter dnspriv dnssec dualwan email eula ftp_ssl hdspindown hnd_ax_675x ifttt iperf3 ipsec_srv ipv6 ipv6pt letsencrypt manual_stb mbo media modem movistarTriple mssid mumimo nandflash netool nfsd no_finiwl ntpd ofdma ookla openvpnd pptpd printer proxysta psta pwrctrl realip reboot_schedule repeater rrsut s46 smart_connect ssh stainfo switchctrl tcode timemachine tor update usbX1 usb_bk user_low_rssi usericon utf8_ssid vpnc webdav wifi2017 wifiradar wireguard wl6 wpa3 wrs_wbl |
Uptime | 0 days 4 hour(s) 34 minute(s) 24 seconds |
Temperatures | 2.4 GHz: 43°C - 5 GHz: 45°C - CPU: 56°C |
CPU | |
CPU Model | BCM675x - Cortex A7 ARMv7 revision 5 (Cores: 3) |
CPU Frequency | 1500 MHz |
CPU Load Average (1, 5, 15 mins) | 0.40, 0.48, 0.51 |
Memory | |
Total | 500.18 MB |
Free | 152.17 MB |
Buffers | 11.77 MB |
Cache | 40.04 MB |
Swap | No swap configured |
Internal Storage | |
NVRAM usage | 71121 / 131072 bytes |
JFFS | 2.65 / 47.00 MB |
