AXE11000 - WPS bug?
smagus
Hi!
I have a strange problem, that I can't activate WPS on 5GHz band. I set it like on the screen below and then turn it on:
It gets activated, but then I see it's active on 6GHz band, not 5.
AXE11000 running latest Merlin.
When I try to activate it for 2,4 then it's ok and activates for 2,4. When I try on 6, it also activates on 6, but when I try on 5, then it's activated on 6:)
What happens if you select 6GHz band?
Report what you see in 388.6 release thread so @RMerlin can take a look.
