[Beta] RT-AC87U 9.0.0.4.378.9110
Hey Guys after installing this beta my log is flooded with this:
Sep 25 18:07:00 Aaews: start to establish a terminal
Sep 25 18:07:45 Mastiff: aae is not running,run aae now
Sep 25 18:07:45 Aaews: start to establish a terminal
Sep 25 18:08:30 Mastiff: aae is not running,run aae now
Sep 25 18:08:31 Aaews: start to establish a terminal
Sep 25 18:09:15 Mastiff: aae is not running,run aae now
Sep 25 18:09:16 Aaews: start to establish a terminal
Sep 25 18:10:01 Mastiff: aae is not running,run aae now
Sep 25 18:10:01 Aaews: start to establish a terminal
Sep 25 18:10:46 Mastiff: aae is not running,run aae now
Sep 25 18:10:47 Aaews: start to establish a terminal
Sep 25 18:11:31 Mastiff: aae is not running,run aae now
Sep 25 18:11:32 Aaews: start to establish a terminal
Sep 25 18:12:17 Mastiff: aae is not running,run aae now
Sep 25 18:12:18 Aaews: start to establish a terminal
Sep 25 18:13:02 Mastiff: aae is not running,run aae now
Sep 25 18:13:03 Aaews: start to establish a terminal
Sep 25 18:13:47 Mastiff: aae is not running,run aae now
Sep 25 18:13:48 Aaews: start to establish a terminal
Any idea what might be the cause?
What he means is that a zipfile allows the user to verify that the download was properly completed and not corrupted in any way (as the zip file uses CRC32 checks during extraction). That would prevent the accidental flashing of an incomplete or corrupted download.
Hi RMerlin,
Noted and in future we will use Zip.
Hi Teymur,
Have you done a factory restore?
I doubt, that with this firmware the 5GHZ is solved problem.
Quantenna it as intel fare. If the driver does not match. No matter how good the hardware is. (Graphic)
Since it takes many years of experience.
Brodcom has it.
First of all is great to see here ASUS_ASUSWRT!!
Factory reset? YES
1. WPS on 5Ghz turns back ON at reboot. A long standing issue since forever.
2. VPN, VPN Client, Open VPN and .ovpn files from VyprVPN (link to config files HERE). Connection is established without problems but internet connection via web browser is broken. It was working fine with older (much older) firmwares. Logs enclosed.
Sep 25 19:58:16 rc_service: httpd 436:notify_rc restart_vpncall
Sep 25 19:58:17 kernel: [truncated] pch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch
Sep 25 19:58:17 openvpn[2643]: DEPRECATED OPTION: --tls-remote, please update your configuration
Sep 25 19:58:17 openvpn[2643]: OpenVPN 2.3.2 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [eurephia] [MH] [IPv6] built on Sep 22 2015
Sep 25 19:58:18 openvpn[2643]: Deprecated TLS cipher name 'DHE-RSA-AES256-SHA', please use IANA name 'TLS-DHE-RSA-WITH-AES-256-CBC-SHA'
Sep 25 19:58:18 openvpn[2643]: Deprecated TLS cipher name 'DHE-DSS-AES256-SHA', please use IANA name 'TLS-DHE-DSS-WITH-AES-256-CBC-SHA'
Sep 25 19:58:18 openvpn[2643]: Deprecated TLS cipher name 'AES256-SHA', please use IANA name 'TLS-RSA-WITH-AES-256-CBC-SHA'
Sep 25 19:58:18 openvpn[2643]: Socket Buffers: R=[122880->131072] S=[122880->131072]
Sep 25 19:58:18 openvpn[2648]: UDPv4 link local: [undef]
Sep 25 19:58:18 openvpn[2648]: UDPv4 link remote: [AF_INET]209.99.63.152:443
Sep 25 19:58:18 openvpn[2648]: TLS: Initial packet from [AF_INET]209.99.63.152:443, sid=d2ca940a 54a25f58
Sep 25 19:58:18 openvpn[2648]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Sep 25 19:58:19 openvpn[2648]: VERIFY OK: depth=1, /C=KY/ST=GrandCayman/L=GeorgeTown/O=GoldenFrog-Inc/CN=GoldenFrog-Inc_CA/emailAddress=admin@goldenfrog.com
Sep 25 19:58:19 openvpn[2648]: VERIFY X509NAME OK: /C=KY/ST=GrandCayman/L=GeorgeTown/O=GoldenFrog-Inc/OU=On_Demand/CN=us5.vyprvpn.com/emailAddress=admin@goldenfrog.com
Sep 25 19:58:19 openvpn[2648]: VERIFY OK: depth=0, /C=KY/ST=GrandCayman/L=GeorgeTown/O=GoldenFrog-Inc/OU=On_Demand/CN=us5.vyprvpn.com/emailAddress=admin@goldenfrog.com
Sep 25 19:58:20 openvpn[2648]: Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Sep 25 19:58:20 openvpn[2648]: Data Channel Encrypt: Using 256 bit message hash 'SHA256' for HMAC authentication
Sep 25 19:58:20 openvpn[2648]: Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Sep 25 19:58:20 openvpn[2648]: Data Channel Decrypt: Using 256 bit message hash 'SHA256' for HMAC authentication
Sep 25 19:58:20 openvpn[2648]: Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Sep 25 19:58:20 openvpn[2648]: [us5.vyprvpn.com] Peer Connection Initiated with [AF_INET]209.99.63.152:443
Sep 25 19:58:23 openvpn[2648]: SENT CONTROL [us5.vyprvpn.com]: 'PUSH_REQUEST' (status=1)
Sep 25 19:58:25 openvpn[2648]: PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.3.152.1,explicit-exit-notify 5,rcvbuf 262144,route-gateway 10.3.152.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.3.152.172 255.255.255.0'
Sep 25 19:58:25 openvpn[2648]: OPTIONS IMPORT: timers and/or timeouts modified
Sep 25 19:58:25 openvpn[2648]: OPTIONS IMPORT: explicit notify parm(s) modified
Sep 25 19:58:25 openvpn[2648]: OPTIONS IMPORT: --sndbuf/--rcvbuf options modified
Sep 25 19:58:25 openvpn[2648]: Socket Buffers: R=[131072->245760] S=[131072->131072]
Sep 25 19:58:25 openvpn[2648]: OPTIONS IMPORT: --ifconfig/up options modified
Sep 25 19:58:25 openvpn[2648]: OPTIONS IMPORT: route options modified
Sep 25 19:58:25 openvpn[2648]: OPTIONS IMPORT: route-related options modified
Sep 25 19:58:25 openvpn[2648]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Sep 25 19:58:25 openvpn[2648]: TUN/TAP device tun15 opened
Sep 25 19:58:25 openvpn[2648]: TUN/TAP TX queue length set to 100
Sep 25 19:58:25 openvpn[2648]: do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Sep 25 19:58:25 openvpn[2648]: /sbin/ifconfig tun15 10.3.152.172 netmask 255.255.255.0 mtu 1500 broadcast 10.3.152.255
Sep 25 19:58:25 openvpn[2648]: Ignore conflicted routing rule: 209.99.63.152 255.255.255.255
Sep 25 19:58:25 openvpn[2648]: /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.3.152.1
Sep 25 19:58:25 openvpn[2648]: /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.3.152.1
Sep 25 19:58:25 openvpn[2648]: Initialization Sequence Completed
For the rest all works fine... no major problems!
Ill out this on this afternoon. Seems mostly positive comments so far which is good.
Do you have AiCloud/ Cloud Sync enabled?
Some tunnel providers will block the use of DNS servers others than those they specifically support, to prevent accidental information leak. Unfortunately I don't think Asus still has the Advanced setting page for clients that would allow you to set DNS support to be exclusive or strict. Try setting this over SSH:
nvram set vpn_client1_adns=2
nvram commit
service restart_vpnclient1
If that doesn't work, try setting it to 3 instead of 2.
thanks! I will try and let you know.
AiCloud/cloud sync? No, not using it.
EDIT: Done but same result. At service restart I get this:
Sep 25 21:38:16 rc_service: service 11792:notify_rc restart_vpnclient1
Sep 25 21:38:18 openvpn[11830]: Options error: You must define CA file (--ca) or CA path (--capath)
Sep 25 21:38:18 openvpn[11830]: Use --help for more information.
My post was assuming you configured client 1. Your previous log seem to indicate you are using client 5... Change all the commands I gave to replace client1 with client5.
Model: RT-AC87U
Firmware version: 9.0.0.4.378.9110
Download Link: http://goo.gl/ud2RKQ
Release Note
Added
1. New wifi driver to improve wifi connection
2. Traffic Analyzer for monitoring your network traffic
3. Bandwidth Limiter in Adaptive QoS
4. USB to USB smart sync mode
5. A scheduler for Router Reboot
6. Can edit offline devices in client list
Update
1. Update OpenSSL to 1.0.2d
2. IPTV ISP profile setting of 'movistar' & ‘meo’
3. Adjust maximum number to 16 for Guest Network MAC filter
4. Web History/Traffic Analyzer can show device name.
5. Allow user paste password on login page
Fixed
1. Media server cannot scan files
2. Cannot complete QIS setting on IE11
3. Download speed is limited by Upload speed in Traditional QoS
4. Unexpected UI display issue
Just installed this beta and am testing it out vs the prod build that is on the support page. Nice traffic monitoring feature.
2 questions.
1. I had turned off beamforming in the prod build because it was causing instability in the 5ghz band. Has that issue been resolved, and should I test it?
2. I've noticed that for some time apple airprint does not work for printers that are wireless. It works fine for printers that are hardwired to the router. I can't determine if it is due to ASUS firmware bugs, or IOS 8/9 bugs. Does anyone have any insight into this?
I have an HP LaserJet connected over WiFi, and I've never had any problems with AirPrint on any of the firmwares...
Thanks. Both the printers I'm having issue with are brothers. Next path to explore....I was hoping it was a router bug that would get crushed over time....
Thanks again. It turns out it was neither the router nor the iphone's. The printer's needed new firmware. perhaps because of the windows 10 update.
I'm still interested in if beamforming is now solid on this build. I noticed that the default after reset is still off. I was having 5ghz problems with it on before.
My log is getting flooded with these messages....
mDNSNetMonitor: GetLargeResourceRecord: opt 65002 optlen 8 wrong
iDevice or two on your network? mDNS is Bonjour/Rendevous/Avahi - which iTunes and iDevices depend much for intranet/internet services..
If so, this might be useful info for QTN on a fix..
Same here, but just on my AP. Started one hour after it was upgraded and 20 hrs later they still appear, sometimes only a few mins apart, sometimes more than an hour. As sfx says, it's part of Apple's Bonjour services. But not found the cause yet.
